Originally Posted by landsailor
Because a +/- circuit conducts voltage, it may not conduct enough amperage to fully power a high draw device such a headlight
That makes sense, because like i said before, i checked the voltage on the ground wire at the plug so the ground is definetley connected, but the connection may be weak and that's why it's giving me a very very dim light from the bulb when i turn on the high beam.
