Originally Posted by t vago
Check your ground wire on your driver side headlamp socket.
+1
You might consider adding a temporary ground wire to see if it fixes the problem.
Or you can get a test light and follow the ground from the negative battery terminal to the light bulb. When the test light glows (probably dim) then you have gone past the bad connection.
regards
Mech
