Old 04-26-2012, 11:07 AM   #133 (permalink)
Daox
The cost issue is mute if you consider that the lithium battery should be able to live several time longer than a lead acid battery, likely through multiple vehicles. If you consider this its actually the more cost effective battery solution. This is very common knowledge in the EV world.
