Originally Posted by hawk2100n
I mounted mine in the instrument cluster. It doesn't block any of the gauges or lights, just the trip odometer reset is behind it. Also it's really easy to run the cable behind the knee panel. It's a nice clean setup that is easy to glance at.
Mine is installed in the exact same place, and works fantastic.
Anyway, if your big on no wires etc, why not a corner window mount? I'm sure it can't be hard to find something that would work. Question though.... how do you mount the scan gauge when there are no screw holes?
