Old 04-27-2012, 12:47 PM   #5 (permalink)
Diesel_Dave
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
Interesting, have you compared your fuel consumption in terms of gal/ton-mile between the two trucks?
The temperature thing perplexes me. Is that info from the Cummins manual or PACCAR? I do know that many of the newer diesels with SCR systems have a "warm-up" mode. The issue is that the catalyst doesn't work until the temperature gets above a ceratin threshold (just like conventional 3-way catalytic converters on gasoline cars). Basically, the engine is trying to get the cat hot ASAP so it can start using the DEF to cut down the NOx. However, there's no reason that the truck can't be moved while it's in the warm up mode--if anything it helps it warm up because adding load helps it warm up sooner. So I'm not sure what that's about.
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
