4 cylinder
8.6cm stroke 8.6cm bore
1998cc
surface area: 348.5cm x 4 =
1394cm^2
8 cylinder
6.83cm stroke, 6.83cm bore
1998.4cc
surface area: 219.7cm x 8 =
1757cm^2
With equal total displacement and identical bore/stroke ratio, the engine with the fewest cylinders ALWAYS has the least total surface area.
The 4 cylinder has less surface area than the 8 cylinder.
Originally Posted by big shafe
Do you have any or can point me to any data that supports this? I would think temperature gradients would be hard to quantify. I also think it would be highly dependent on fuel/air mixture distribution and fluid flow characteristics.
I could possibly see that for similar compression ratio's but not sure about large compression ratio differences.
The bigger the cylinder volume the lower the BSFC. Its a well established linear relationship.
