Old 04-27-2012, 05:58 PM   #16 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
I really like the concept and have thought of it much a long time ago. I got hung up on having nice, responsive controllability of it and concluded it would really have the most merit on stationary engines or engines that don't see such a wide range of throttling and rpm conditions, maybe tractors, mowers, generators, etc. but then of course there is the complexity and expense. Could be wrong about that though!
With the advent of computer controls and ever faster response times in said controls, I think it's something that could be a reality today.
Using all the same sensors currently in use, possibly a few more, to define the "curves" necessary for each solenoid's map set.
The first thing I'd ever bother trying it out on would be a single cylinder briggs or something, though, because the designs are transcendent and if it works on a single cylinder, it shouldn't be /too/ hard to adapt to more, if we're to treat each cylinder of an engine like it should be, as an individual engine, independent of the other cylinders.
