Originally Posted by 3-Wheeler
What Mr Miller pointed out earlier, multi engines are preferred for more power output, since they allow higher valve area per cylinder volume, and higher rpm's, BUT at a lower operating efficiency. Back in the late 60's Honda was famous for it's family of multi-cylinder race engines, including a 250cc 6-cylinder.
Is it the valve area per cylinder volume or is it the balance aspect? You can increase valve area by shortening stroke and increasing bore, but then I guess there are combustion issues when the bore gets too big or something.
I believe 6 cylinders are used in luxury cars because they are smoother, and I've heard that the reason for V10 and V12 rather than a fat V8 is because of better balance or something, not sure. They sure do make a great sound
