I've been reading about blocking the grill on the threads. Is that mod only to keep the engine warm or are there any more benefits?
I just checked the tire pressure and they were at 29PSI and the max pressure is at 44psi so I put more air on them so that should help more and I also started using the pulse and glide technique so we'll see how that goes when I fuel up the car again. I can only check numbers when I fuel up since it does not have an obd2 connection.
