Less cylinders for FE always wins, not only the lower surface area for the volume but also less friction from cams and crank bearings.
HP is is on the other end of the spectrum, HP is limited by airflow which is controlled by bore size (in relation to stroke) in a Naturally aspirated engine. More cylinders are also beneficial in this regard.
Reason: spelling
