Originally Posted by bazman
I'm going to look at various kits including the ERL Aquamist (ran them before and they work great), Devils Own, Snows and some new ones I've not heard of before like Hydramist that uses Aquamist components. There is also this one that uses a mechanical pump to force the water to atomize rather than an electric high pressure pump...
One idea I've been contemplating.
use a diaphragm pump to pump water to 50 psi or so. Run the line through copper, then heat it off the exhaust so the temps get up somewhere near 250 degrees or so.
then run it through a fuel injector, and inject it under the throttle body.
Piggy back the fuel injector off the main throttle body fuel injector so the pulse width is the same as the fuel injectors pulse width.
The idea is the water would follow fuel flows, which obviously is a pretty good indication of engine loads.
The higher temperature of the injected water means when the water hit the intake manifold it would pretty well atomize - you would not get pure "steam" per se, but you SHOULD get pretty good atomization, just like the fuel gets atomized by the injector pretty well.
