Originally Posted by dfregozo
I've been reading about blocking the grill on the threads. Is that mod only to keep the engine warm or are there any more benefits?
It's mainly to reduce drag.
Air going in and thru the engine compartment causes a lot of drag.
A grille block minimizes the air coming in.
I just checked the tire pressure and they were at 29PSI and the max pressure is at 44psi so I put more air on them so that should help more
Keep an eye on tyre wear.
The extra pressure does alter the wear patterns a bit.
Higher pressure actually evened out the wear on my tyres
![Wink](/forum/images/smilies/wink.gif)
They were wearing more on the shoulders despite being run at "correct" pressure.
