Old 04-28-2012, 10:18 AM   #4 (permalink)
Cd
Ultimate Fail
Cd's Avatar
BTW, speeds in the above test were approximately 40 mph, and the chase vehicle was a Saturn coupe.
If you haven't done the test yet, I'd like to suggest adding tufts at the C pillar and trailing on down to the edge of the trunk/boot.
Of course a visible color of yarn is preferred. When I did my test, I found that using super small diameter line ( "string "? ) seemed to give better results than actual yarn, since the yarn has " hairs" which stick to one another and cause drag from the yarn itself .
I used line that was perhaps 1/ 16 " or smaller, and no longer than 3 1/2 " - 4 "
Any longer and the line gets flutter which skews the results.
( I tested several colors for visibility as well as different lengths and materials - yarn and line.
The Following User Says Thank You to Cd For This Useful Post:
drmiller100 (04-28-2012)
