Old 04-28-2012, 10:42 AM   #50 (permalink)
bschloop
sr185 bullet - '81 Yamaha SR185 streamliner
Team Streamliner
90 day: 96.35 mpg (US)
Sunny Colarado - '06 Chevrolet Colarado WT
90 day: 24.18 mpg (US)
cbr250s - '12 Honda cbr250
90 day: 115.29 mpg (US)
I got the bottom glassed in, and that's the last of the fiberglass, I also set up an led taillight, and found an led headlight bulb,
Euromodder, I took your suggestion about the foam, I left it in the leading edge of the fiberglass bottom, around the wheel, it seems to be working well, I also filled the tips of both the top, and bottom of the tail with expanding foam to ensure it is sealed.
Redyaris, I did have to make the lid a little taller, but not due to seating position, when I tried to put the groceries in they were squished against the top, I will probably bring it back down after the Challenge though, since I don't usually use paper grocery bags anyway, and it seems slightly more susceptible to side wind this way.I can still carry more than enough stuff, I can almost crawl right into the tail, probably could if I tried.
ID:	10749   Click image for larger version
The Following User Says Thank You to bschloop For This Useful Post:
renault_megane_dci (05-07-2012)
