Does anyone know if any other car manufacturers used digital MAP sensors? From my research, digital MAP sensors use a square wave output in frequency whereas analog MAP sensors us a voltage output. Ford is the only make I can verify. I'd like to find a MAP sensor using higher frequency so I could keep my cruise set at 4000 PPM and just put the VSS & MAP wire on a relay/switch.
