I had a 04Lincoln Towncar, not the most eco friendly. I went from getting epa numbers, 16/23- to 20-28 with an air dam under the nose and a lower grill block,and inflateing the tires to 40psi.
There was an air scoop for the rad and i built the air dam off. The airdam went to the front tires.
