Old 04-30-2012, 07:09 PM   #15 (permalink)
RiderofBikes
Pantry Boy Supreme (pbs) - '04 Volvo S80 T6 Premier
Originally Posted by Christ View Post
Read my note about load and automatic transmissions. in theory, it shouldn't change the engine speed while under lockup, though.
So... for ATs
Could it be that the AT/converter reaches a "lockup" state sooner, based on the effort needed by the engine to maintain a given speed?
Less load= less required power= lower rpm to do the same amount of work?
I know gearing and ratios are in there somewhere...
But then what is the correlation from an up-right riding position to tucking, and gaining anywhere between 1-5mph without changing throttle position with an MT? when were talking about stock gearing/ratios... i know it should be constant regardless... but this is not what im experiencing, im experiencing a gain in speed in this instance.
Maybe im just not getting IT
