Old 05-01-2012, 11:24 AM   #4 (permalink)
LeanBurn
Got MPG?
The Car - '09 Toyota Corolla CE Enhanced
Oil has developed quite a bit in the past 20 years...even the past 5-10 years. Back in the 1990's 15w-40 was probably the only oil that could handle the soot and pressures. Today's conventional oils are as good as that eras synthetics if you can believe it.
That Amsoil HDD oil is great stuff. Use it with confidence and enjoy your new improved fuel economy.
2013 Honda Civic Si - 2.4L
OEM front to back belly pan from the factory.
