I actually replaced a bulb on my Focus this weekend and was shocked to find that it was a very simple, toolless process. Just unscrew a cap, flick a wire clip, and unplug. This may be the first thing about this car that makes me really happy.
Focus should be called Ford S/B...Surprise Box
Wait until rear suspension bushings goes,control arms/links needs to be replaced + wheel alignment = Katching!
BTW the coil springs are most likely broken at bottom,but can't see until removed.
I have a 98 Sunfire 2.2L and that's the only thing silly to work on so far...
Headlights tends to die due to a fragile ground wire that breaks.
Fun/easy car to work on
If i could only find out about a possible 5th gear swap...
