Welcome! Suggest you pose the propane question in another section.
Check out the search feature upper left.
After your swap, the rest should be easier! Reduce mirror size. Get an airdam going,
rear wheel skirts, under body side skirts might do A LOT for you!
Under body pan certainly couldn't hurt.
But nothing will work as well as adjusting the nut behind the wheel.
Gentle finesse, smoooooooooothness, in your driving will be key!
06 Chev MonteC JG#24tribute car 30mpg 00 Honda Insight 63MPG 98 Buick Park Ave3.8 33MPG 89 Toyota Corolla wag 53MPG so far 81 VW Rabbit diesel pu 50MPG+ 80 Mercedes 240D stick 30-ish 90 vette 6-speed,29ish 07 Honda ST1300 55MPG 83 Honda 650 GL 64MPG 19 Suzuki dr200 88MPG23 HondaGrom?+Tow K10D Sub 26mpg NEVER,NEVER GIVE UP!
PUMP THOSE TIRES UP!
DRIVE IN YOUR SOCKS FOR SENSITIVITY!!!!!!!!!!!!!!!
SLOW DOWN AND SMOOTH UP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
