Originally Posted by mwebb
DO NOT ADVANcE THE INJECTION PUMP TIMING
it will enrage the ECM and you will have starting issues .
set injection pump timing as per the VW specifications
use VCDS if you have it
your FE is pretty outstanding as it is
do buy
VCDS / Vag Com if you do not have it already
do make sure you have NO bubbles or air in the feed line to the injector pump
do not use BIO diesel
I will keep the IP timing just where VW wants it.
I have VCDS
And thanks!
