Old 05-02-2012, 12:14 AM   #6 (permalink)
nimblemotors
EcoModding Jack
nimblemotors's Avatar
The Plug-in mod for a Prius sounds really good, until you find out all the real actual details and limitations and issues with them. I don't think they are worth it after I looked into them as possible a business installing them.
The Enginer keeps the heavy OEM battery, and in fact, overuses it so it won't last as long and gains you very little and adds a lot of complexity (and failures) The others are expensive and then you don't even really have an PHEV, you have a prius hybrid with more battery, not an EV with gas backup, because it NEEDS the gas engine to operate properly no matter what some want you to believe.
The Following User Says Thank You to nimblemotors For This Useful Post:
govman6159 (05-02-2012)
