Originally Posted by mwebb
or
you could find the value of the temperature switch / sensor that controls fan operation and
find one with a higher "on" value
that way
your cooling fan only functions
when needed
and when needed by your engine your cooling fan is not in your basement
Done this to three vehicles now, never had an overheat situation because of it. I will install a spray bar and use washer fluid if the temps get too high as a precautionary measure.
