Old 05-02-2012, 11:29 AM   #10 (permalink)
Fat Charlie
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
I'm supposed to remove my front fascia to get at the bulbs. Riiiight. Of course if you can't see what you're doing very well because you're doing it with everything in place, then you just might break a retaining spring. That's only serviced as a headlamp assembly. My right low beam bulb has been held in place with mechanic's wire for the last four years.
Transmission type Efficiency
