Old 05-02-2012, 10:50 AM   #203 (permalink)
oil pan 4
Originally Posted by bazman View Post
they can only cope with either boost or vacuum not both.
My water/methanol pressure regulator system would work with both boost and vacuum.
If you read the water injection wiki you would see I have found a part for or solved every problem you have except for "an electronic injector".
The only reason I have not found an "electronic injector" is because I have no need for one.
bazman (05-02-2012)
