Old 05-02-2012, 11:45 AM   #208 (permalink)
mort
EcoModding Lurcher
mort's Avatar
Originally Posted by ecomodded View Post
A Briggs & Stratton 4-stroke lawn mower engine would make a great test subject for water injection.
A mad scientist could rig up his water injected lawnmower and do a-b-a testing on gas usage for a set track consisting of the front & back yard, undoubtedly.
edited to add-
You could run the motor on the bench, running for a set amount of time for a-b-a-b-a testing. Although your neighbors may prefer if you were to cut the lawn..
Hi ecomodded,
When you add water or steam the flame speed slows including increased ignition delay. You'd need to be able to advance the timing, which I can't do on any of my small 4 strokers. Is there a way?
-mort
