Old 05-02-2012, 05:13 PM   #10 (permalink)
ConnClark
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
More boost raises engine efficiency on diesel though you get diminishing returns as it increases.
http://web.archive.org/web/200611080...4/A6_1_022.pdf
The question of whether more boost will help on a particular engine depends on how much more energy it takes to create the additional boost, the efficiency of the system doing so, and the increase in friction due to running at higher pressures (note that the above paper showed efficiency increases all the way up to five atmospheres).
