In response to electricstorm, I'm also using a forklift motor in my S-10. It's a GE motor a little over 11 inch and in the 200 pound range. Except for the spline shafts and different bolt pattern on the output side, It looks exactly like the NetGain Warp 11 motor. The motor was rated 13 hp @ 48 volts, 150 amps, 1800 rpm, class H insulation. Class H insulation is good for up to 356 deg. F and 600 volts or so. Generally the type of brushes in that motor are only good for about 78 volts. But I have been running 144 plus volts for 10000 miles and have noticed no abnormal brush ware. I did set my brush timing to 6 deg advanced to reduce brush arcing which works for my motor with the load it's under. Hope this was helpful.
