Old 05-04-2012, 01:43 AM   #1 (permalink)
larrybuck
larrybuck's Avatar
Location: sw Washington (state), a little north of Vancouver
Are you cheap in MOST all you do?
For example: If you are just drying your washed hands w a paper towel,
w no residue on it, would you lay it aside to dry?
In what I would call desert wash, (not much water around) would you stand at the sink, and wash yourself in sections (like a large car?) with the hot water barely on, maybe all off during rinse wipe?....instead of a conventional shower???
And use the thinnest wash cloth possible for quicker soap gone rinsing?
When cooking, do you do anticiple cooking ( like a car coasting ) where you turn a burner off early just enough by practice?
Do you use timers for your heat at home?
Young single guys usually do smell tests before committing to laundry?
If no women were around; what would you set a thermostat at?
Do you live in a situation w a woman where you almost have to go around in the place w little on because SHE must have Roast?
Does anybody manually wash dishes w an available dish washer standing by, and leave pots or other recently washed items out on a counter to air dry?
Do you keep a place so cold that nothing almost would air dry?
Just wondered!
PS... Is anyone willing to watch a smaller TV because it costs less, AND
uses less Juice???
06 Chev MonteC JG#24tribute car 30mpg 00 Honda Insight 63MPG 98 Buick Park Ave3.8 33MPG 89 Toyota Corolla wag 60MPG so far 81 VW Rabbit diesel pu 50MPG+ 80 Mercedes 240D stick 30-ish 90 vette 6-speed,29ish 07 Honda ST1300 55MPG 83 Honda 650 GL 64MPG 19 Suzuki dr200 88MPG23 HondaGrom?+Tow K10D Sub 26mpg NEVER,NEVER GIVE UP!
PUMP THOSE TIRES UP!
DRIVE IN YOUR SOCKS FOR SENSITIVITY!!!!!!!!!!!!!!!
SLOW DOWN AND SMOOTH UP!!!!!!!!!!!!!!!!!!!!!!!!!!!!![SIGPIC]
