Originally Posted by woodstock74
Well I bit the bullet...
"Tested" it, went up and down the interstate to make sure there was no buffeting or anything untoward. At very least it isn't hurting. Unfortunately I don't have any better data acquisition at the moment other than the MkI eyeball and tach vs. MPH reading. So initial look showed we're inching closer to 2600 RPM @ 68 mph. Before I started all this 68 was just below 2800 rpm. Now we're just above 2600 rpm. The tale will be the fill up. Though need to look into a ELM adapter for the OBD. Has anyone tried the Torque app for Android? Sounds like a Scanguage for $20 (about the cost of the ELM adapter, the app is free).
What's the clearance from the bottom edge of the added air dam and the ground?
What's the clearance from the bottom of the body to the ground? Front to back?
