Lets stick to facts, name calling for later......
DynoValve- I own one and love it!
Dynovalve =Computerized PCV valve. Traditional PCV valve is thing of the past.
With a computerized PCV valve you are able to to recirculate wasted gases. Over time sludge is developed by "unused fuel". This unused fuel ends up as sludge in the crankcase. With the Dynovalve this "unspent fuel" gets burned.
With the age of vehicle playing a part, more wear on pistons and rings allows for more "blow by" gases to be burnt in the Catalytic Converter. (another thing of the past).
Many things benefit from a Dynovalve- longer engine life, less oil changes, MUCH lower foot print and fuel savings to name a few.
The Dynovalve has an EO (Executive Order) from the State of California. California is the LEADER in smog controls and has the most restrictive laws in the USA concerning smog. You cannot get an EO without independent testing by CARB (California Air Resources Board) in California.
Buy one, install it, check it out for yourself.
