Originally Posted by dfregozo
I also want to add a K&N air filter to allow more air into the engine.
So you can add more fuel?
Save your money.
The only time you want more air is if you are trying to squeeze more max hp out of it.
Actually, that's not quite right. You want more air, hot air, that is, which has less oxygen.
Living in phoenix, hot air is in abundant supply.
You want that air as hot as you can get it, which means you need a higher throttle opening for a given quantity of oxygen.
You still may be able to use a grill block, assuming your coolant system is in good shape.
