Originally Posted by BenjaminT
I'm only asking because I've seen it before as a tech, but. You are using oil for a "compression ignition" engine, correct? I just don't want to see you ruin your very expensive engine.
It's Amsoil Series 3000 Synthetic 5W30 Heavy Duty Diesel oil. If you look at the tech specs here you'll find it's pretty impressive stuff:
AMSOIL - Series 3000 Synthetic 5W-30 Heavy-Duty Diesel Oil (HDD)
It's specifically designed for diesels. I don't know of anyone specifically that's run this stuff in a 6.7L Cummins like mine, however, I had heard great reviews from guys who had used it for years in the 5.9L Cummins. The 5.9L was bore and stroked in 2007 to create the 6.7L engine, and I believe the lube system stayed basically the same, so I didn't see any reason why I couldn't use it in my 6.7L.
