Originally Posted by pete c
You do also need to realize that one route is likely shorter than the other. So, the longer way might give better mileage than the shorter way, but, still burn more fuel.
I had not thought of it that way, but you are completely right
. I will check what is the difference in mileage, and try it to compare. The hwy takes me through some hills and the streets don't so there may be difference.
