Old 05-07-2012, 05:53 PM   #221 (permalink)
renault_megane_dci
la_voiture_de_courses - '03 Renault Megane Estate
OldContinents
90 day: 44.34 mpg (US)
xiao lan - '01 Audi A2
90 day: 38.88 mpg (US)
Brit iron - '92 Mini Mini
90 day: 45.5 mpg (US)
Prius - '09 Toyota PRIUS Lounge
90 day: 47.37 mpg (US)
Beemer - '06 BMW F800 ST
90 day: 53.06 mpg (US)
I have been reading somewhere that you get good improvements in mid range on a DOHC bike when altering the timing 4° on both inlet (later opening) and exhaust (earlier closing).
The idea is to have (8°) less overlap which cause erratic running at low rpm but is a consequence of the longer duration cams that are found in high power / liter engines.
4° on each cam being still safe with valve to piston clearance.
There was something to do on the ignition timing too but I can't remember it.
Also, if uing the engines only at lower rpm, we could increase the compression ratio wich is a big MPG booster.
On my 250 GN, I plan to boost the CR and polish the chamber and maybe piston crown but unfortunately, being SOHC, I can't play with timing ...
