Old 05-07-2012, 07:07 PM   #19 (permalink)
dean_park
GLF TDI - '11 Volkswagen Golf TDI
90 day: 49.07 mpg (US)
I'd ignore the grammar police... There's at least one on every forum.
The scangauge is an excellent use of your money though (try to pick one up used to save even more). I bought an Ultragauge @$60 for my last car and it did almost as much as the scangauge and I personally thought it looked better.
The grille block, air dam, weight reduction and spoiler delete will probably help quite a bit on your highway mpgs, but I'd look at getting the gauge first, to truly know what your engine temps, coolant temps, etc are doing. If delivering in a lot of stop and go in the heat, you may cause some issues. It may be a good idea to plan on removable air blocks for working and adding them for highway or sustained speeds.
