Old 05-07-2012, 08:09 PM   #9 (permalink)
Grant-53
The pusher trailers I've seen online are two wheelers with hitches mounted to the rear drop out area. I'd go for a frame mount motor. If you are planning for low speed torque, use a parallel battery connection. Is there an rpm rating on the motor?
