RH77 -
Originally Posted by RH77
HDD magnets are a great idea -- strongest magnets I have laying around too...
With your design, have you looked at the airflow for the condenser? I believe the front of the unit (on the outside) is the outgoing hot-air flow from the condensing coil. ...
Not yet, I don't want to turn on the $AC$ until I have too. Hrrmmmmmmm, now I wonder if the venting heat will melt the coroplast. Doubtfull, but maybe I need to turn it on under test/monitoring conditions.
... If you a fresh-air inlet, I think the fins on the side pull that in (optional and not the most efficient setting).
I always set the fresh air inlet to draw air from the inside because it will only be on when it is hotter outside. That would be easy to test, however.
Have you checked for the warm air flow by the front panel? Otherwise, the shade would help. I think one of the links earlier showed a spray with red dye for for unit's stand-alone unit's exhaust fan (the amount of air flow is considerable -- it nearly reached the top of the test home.
I thought about some sort of shading as well, but I'm afraid of choking the flow. It would have to be a tall, awkward looking fence -- but that unit sure bakes (near the Southwest corner with no shade protection). Hopefully the mist is doing something other than scaling the living daylights out of it!
RH77
I think (not at home right now) my unit is an 18,000 BTU (1.5 ton) AC unit, so I don't think the flow will be toooooo great. I may increase the space of the vertical panel (see how it angles down and in), but I did the vertical panel last and was a bit more lazy towards the end of the setup.
Ha ha, I just realized I *could* go techno-designer insane if I wanted to. The Coroplast comes with "channels" that could be circulating water. I'll bet it would get dirty/clogged in no time, however.
CarloSW2
