Trim something up the right shape, clean the surfaces, and use windshield urethane to glue it in. (3M Window Weld is a Godsend in my line of work.) Use gloves, rags, and lacquer thinner on for smoothing/cleaning. Just position it right the first time. You do not want to have to remove it again.
Also, I would imagine your power mirror circuits to be normally open.
