Old 05-08-2012, 08:18 PM   #15 (permalink)
JRMichler
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 37.93 mpg (US)
If Ford spec'd 5W20, then 0W20 should work just fine. The 0W rating is cold viscosity, the 20 rating is hot viscosity. She will have less drag with the engine cold, same drag with the engine hot. You do not want to reduce the hot viscosity - that's what keeps the cam lobes from getting destroyed.
If her driving is in the 40 MPH range, I'd check the AT torque converter lockup speed. The most economical speed is the lowest speed where the torque converter stays locked up.
Study up on DWL and DWB. Those will do more for mileage than aero improvements.
The Following User Says Thank You to JRMichler For This Useful Post:
dopplereffect98 (05-18-2012)
