Old 05-08-2012, 09:25 PM   #15 (permalink)
JRMichler
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 40.78 mpg (US)
Very bad idea. The thermostat does several things.
It helps the engine warm up faster. Warmer engines get better MPG. We use grille blocks to help engines warm up faster.
It keeps the engine at constant temperature. Constant temperature is good for engines. They run most efficiently at a certain temperature, and the thermostat keeps the engine at that temperature. That said, some engines run better with a thermostat slightly hotter than factory original. Others don't.
A missing thermostat sends too much flow through the radiator. This can reduce the flow through the engine block and cause hot spots.
