Turbulators (which I'm guessing are essentially vortex generators) will work against your cause. You want smooth airflow- the point of the boat tail is to reduce turbulence as far back as possible. With the 20* angles and generous radii you should have attached, smooth flow the whole way back without issue. Tuft test to make sure.
Also be sure you make a belly pan to lead up to the boat tail to take more advantage of its benefits. You want the tail to continue smooth airflow, not start it. If you have turbulent air coming onto the tail, whether from VG's or a dirty under body, it will not work as well as it could.
