Thread: 50mpg truck
Old 05-09-2012, 06:15 PM   #19 (permalink)
jamesqf
Originally Posted by euromodder View Post
A station wagon will do most of what trucks are used for.
If one still needs more volume of weight capacity : use a trailer.
I think you've got that backwards: a lot of truck owners are just using them as station wagons.
There are a lot of things that a truck will do that station wagons can't, because they lack the ground clearance to handle rough roads. If you get a station wagon that will pull a trailer hauling significant weight, such as a load of logs for firewood, a two-horse trailer, or even a good-sized load of hay, then that station wagon is going to be almost as large & thirsty as a truck (in fact, it'll probably be a fairly large SUV), and you will be driving it all the time and getting lousy mpg.
