Thread: 50mpg truck
Old 05-09-2012, 08:45 PM   #24 (permalink)
radioranger
radioranger
you could probably get t down to 23 or 24 hundred pounds then aero the tail and optimize the engine, most engines run too rich to keep the cat hot i understand, so lean it out a bit and electric fan etc, also modify the nose and tail sections as much as you can , then you should be able to get close to 40 mpg all the time on the highway . 50 mpg could be a reach .
