Old 05-09-2012, 10:16 PM   #21 (permalink)
Shawn D.
Harebrained Idea Skeptic
The White Car - '84 Mercedes-Benz 300td
90 day: 28.84 mpg (US)
The Blue Car - '86 BMW 535i
Last 3: 23.86 mpg (US)
Originally Posted by Gasoline Fumes View Post
... I can't use ramps...
You certainly can use ramps!
Not only are there low-angle ramps available commercially (here's just one example), you can make your own.
I got a 2x10"x12' board, cut it in half, then into 2' and 4' sections. Bevel one end of each section (at a shallow angle so your tire doesn't just push the ramp) and stack them using wood screws. Now you have a pair of low, wide, stepped ramps. If my lowered BMW with an air dam can get up on these, your Honda certainly can.
The Following 3 Users Say Thank You to Shawn D. For This Useful Post:
aerohead (05-10-2012), Gasoline Fumes (05-11-2012), seifrob (05-11-2012)
