Originally Posted by skyking
The elaborate part is the automated control. I will start out with a window switch and watch the gauges.
What do you plan to use to open the shutters? The most basic would be a hood popping cable... or maybe a bike gear shifter that way each "gear" would be a different level of flow. having control over how much the shutters open would allow you to keep a perfect balance between cooling and aero
