Actually, the pictures of my tail I got from work where people made fun of my bike !
But for some reason, I can't get them to load on the server I am usually using.
You'll have to wait tomorrow ...
The toughest part to source so far were clip-ons as the fork is so tiny (33 mm).
There is always the option to butcher an upper clamp but then again, none came up on our french equivalent of craig list : Le Bon Coin.
Euromodder :
A 17" rear wheel I have already sourced but it doesnt have a rear sprocket damper and I will have to convert to rear disc.
Smaller sprocket I didn't found over the counter, I need to check how much could be a custom one or what I can adapt.
The bigger wheel comes with a longer swing arm wich I fancy fitting fitting since the bike is not too stable at speed ...
Also, it looks way hotter
I have a question for you guys :
Wich shall I favour :
more horizontal windshield with pretty bad air tightness with the headlamp
or more horizontal windshield more air tight
So far I have been riding with the more angled one but converted it to the more vertical one yesterday.
