Originally Posted by renault_megane_dci
I have a question for you guys :
Wich shall I favour :
more horizontal windshield with pretty bad air tightness with the headlamp
or more horizontal windshield more air tight
I'd say you would be better-off having it laid down as much as possible to smoothly deflect the air over your head and not worry about the amount of air that will enter above the headlight. If you feel it's significant, and adding drag, just make some type of filler to block it. Or you could drill some new mounting holes so it could drop down tighter to the headlight in the new position.
Jay
