Old 05-10-2012, 09:05 PM   #5 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
If you want to further control the airbox heat, you can use a thermal switch and an electronic valve. Place the thermal switch somewhere in the intake tubing to monitor air temps, wire it to a controller on the valve you already have in place. In this way, the valve will shut off at X temp, and open back up below X temp, keeping a close range of temps in the intake tract. Different switches will allow you to fine tune for the best IAT for FE.
I had a similar idea quite awhile ago, wherein I'd use a small heater core mounted in the airbox. I never got around to doing it, but at least someone is... if it works for you, I might also give it a shot.
The Following 3 Users Say Thank You to Christ For This Useful Post:
chumly (03-05-2017), ECONORAM (01-03-2013), t vago (05-10-2012)
