Originally Posted by renault_megane_dci
Smaller sprocket I didn't found over the counter, I need to check how much could be a custom one or what I can adapt.
What size of sprocket do you have on it now ?
Try the UK for weird things if you can't find it locally
Wich shall I favour :
more horizontal windshield with pretty bad air tightness with the headlamp
or more horizontal windshield more air tight
Try to line it up with your shoulders then see if the buffeting can be improved by putting it more vertically or horizontally.
A gap between the screen and the lamp isn't bad, it helps filling in the "vacuum" behind the screen, resulting in less buffeting for the rider.
Screens are very much trial and error / hit and miss.
Even BMW missed the mark big time with their small clear screen on the R1200R. The buffeting was debilitating.
